Time for a clutch
The clutch is slipping so it's time to upgrade.  It's so bad I hope I make it home.
Which online store has good customer service and sells southbend clutches?
  • Replies 25
  • Views 5.4k
  • LegendaryKing
    LegendaryKing
    Truck is stock for now.  I'm researching the most reliable way to meet my 400-500 hp goal and I'm conservative and tend to over build for reliability.  This comes from my time building racecars.  Ligh
  • Diesel auto power. They are a vendor here. You can also talk with SB direct about your also.
  • Tractorman
    Tractorman
    Southbend's part # HYDX1-50 has an adjustable pedal feature.  This is important as the OEM and other aftermarket non-adjustable pedal clutch hydraulics will likely frustrate you because they probably
Dual disc is typically for 550 HP and up. Talked to Peter at South Bend as well on this and shift behavior is a bit different. Single disc typically performs better. Like I'm on my second Con OFE clutch and no issues towing or exhaust brake usage.
https://mopar1973man.com/garage/modification/258-south-bend-ofe-clutch/
I guess that brings a question, how many miles do these seals go before developing a leak.
Well now there's a question with a ****load of variables.  Machining tolerances of both the crank and the rear cover will affect it, as well as the tolerances of the seal itself.  Was the crank machined 0.0005 larger than spec while the seal was formed -0.0005 below spec?  There's quicker wear on the crank and more chance of leaking.  Does the seal fit tight enough in the rear cover that the sealant is more effective than a looser fit?  What kinds of heat cycling has the seal seen?  How much lateral and axial play is in the crankshaft? Is the seal true or out of round?  This list can keep going for a long while.  Sure, you can calculate an 'average mileage' for the seal life, but with so many outliers in both directions an average won't mean much.
Edited by trreed
Thanks for clearing up the mud on that. I feel better already, still got a leaky seal though.
8 hours ago, dripley said:
As stock as you are, why the dual disk?
Truck is stock for now.  I'm researching the most reliable way to meet my 400-500 hp goal and I'm conservative and tend to over build for reliability.  This comes from my time building racecars.  Light weight, high strength, low cost; pick 2.  I'll probably end up building a truck capable of handling 700+ and feed it a diet of 450ish.  At least that is the track record I have so far.
I have driven and built a number of multi-disc clutches over the years.  The shift quality remains OE in all of them; however the clutch tends to grab right away ... There is no slipping a clutch in traffic to keep you out of the guy in front of you's trunk.
If the rear main seal isn't leaking I'll leave it be.  Thanks for your help everyone.
BTW, clutch is already here.
Nothing is simple anymore,  I hear ya.
