Hard Start unless factory lift pump disconnected
- Replies 14
- Views 4k
Mopar1973Man 4 posts
Jake 4 posts
Dieselfuture 2 posts
adamey1000 2 posts
UPDATE. I replaced the factory Denso. Starter with a made in China amazon replacement (I know I know) and it fired up almost immediately. Before I get grief for the amazon starter. I have an abundance
I was having the same issue. Once warm it wouldn’t start unless factory lift pump was disconnected. New VP solved that. Now I have a FASS on a relay but no delay and it starts up after one revolution
I did the oversized contacts and the plunger, but it still spun slow. I moved those over to the new starter before I installed it.
I’ve searched quite a bit for info on this subject.
But it always seems to pertain to trucks with after market lift pumps. My truck still has the stock lift pump. Are these hard starts still a VP issue? Truck runs just fine. For now I’ve installed a toggle switch off the ground wire of the stock pump. As long as the pump isn’t running starts right up I’ve yet to install a fuel pressure gauge which I know is a must. Was also looking for suggestions on a good one and wear to hook it up
