iQuad Boost Readings Lower than Boost Gauge
- Replies 50
- Views 9.7k
Cummins4life 17 posts
Me78569 10 posts
Cronus577 8 posts
dripley 5 posts
please check the jumper on the box. FYI it is impossible for the ecm to see 36 psi at wot, that boost fooling curciut will not allow it.
Just curious about this. My truck never see 400-500* at idle, cold or warm. Mine maybe sees 300* on cold starup. The EB will bring it up in the 450 range. Idleing in summer time on warm engine i will
I dont know. After 17 years it kind of looked crappy to me. Still works fine best I can tell but most tlikely needs a rebuild. 455k miles on it+many hours of idle. Still no play in any direction in it
Just curious if anyone has experienced this before. I recently installed a Adrenaline with iQuad on my truck. When monitoring the boost reading from the iQuad on my phone it reads about 3psi lower than my other boost gauge. I have a 0-60 Autometer elite, its not a junk gauge and has never been over pressurized since my truck is mostly stock so I would expect it to be accurate. Could this be a conversion thing with how the Iquad produces its boost number or a sign of a failing MAP sensor? Truck runs great no weird issues I have noticed just curious since if it is low all my fueling will be thrown down 3psi levels.
Thanks
