Looking for Ideas on intermittant miss.
- Replies 7
- Views 2.5k
Mopar1973Man 2 posts
ISX 2 posts
Wild and Free 1 post
AH64ID 1 post
I have had an issue with my 02 for about three years now. When it is cold out it runs like a champ. as the temps pass 60-70 degrees and the engine is hot it develops an inconsistant miss. It only does it in warm weather with a hot engine. It developed after I installed the 155 hp BD injectors and an II HRVP44 pump. They were installed about a week apart in the spring while it was still cool out so I never could isolate which caused it.I Have read that a bad vp44 computer will cause the miss when it gets hot.The next thing is if It is in gear or has any sort of load on it like head lights on or ac on ect it will run smooth but put it in park with every load sucking option off them it misses. It is not a solid consistant miss either it sounds like morse code and it will miss through the rpm band as it is reved up with no load also.Seems the hotter it gets or after pulling a heavy load is when it gets the worst.Any ideas?It was a fresh II HRVP44 when I installed it about 3 years ago which is where I think the problem lies.
