- Replies 17
- Views 6.7k
dripley 6 posts
Mopar1973Man 4 posts
CAMG3X 4 posts
Dieselfuture 3 posts
@Mopar1973Man The 02 wiring diagram is different than the one you posted. It only has the oil sensor and the map sharing a 5v signal wire and not the cam sensor My spare harness has a 5v to the m
Be aware a bad oil pressure sensor can foul the MAP sensor. This is a little secret from another member.
Yeah it is a bit cluttered down there. My filter canister only has 2 bolts and can easily be moved if it is in the way. I have never unplugged mine, never had reason to.
I'm working on diagnosing a P0237 code. I installed a fuel boss and primed the system by cracking the injectors resulting in fuel down the side of the block. Wondering if that could have caused it or I bumped something out of place.
I removed the MAP sensor and cleaned it, appeared in good condition.
Attempting to follow the steps :
Though, my OBDlink mx is unable to read MAP voltage. I'm getting Mass air pressure readings, could the boost on the Quad be at fault?
Going to disconnect the harness and see if I can get a voltage reading off the plug with the multimeter tomorrow.
