- Replies 8
 - Views 1.7k
								dave110 2 posts
								Dieselfuture 2 posts
								Russ Roth 1 post
								Sycostang67 1 post
If you don't mind doing it yourself, you got several options. 1 part store. Measure the length you need and piece it together, more than likely they won't have exact length. Some stores around h
I dfon't know about legality but they are not good enough for the pressures you see in a brake system IMHO. On Moparts if that suggestion is even a thought it is shot down so fast it would make your
Went out this morning to go eat and as soon as I backed out of the driveway, brakes started going away. Pulled back in and fluid was gushing out of the frame near the front of the fuel tank. Huge rust out in the hard line.
Tried looking up this part in the lookup tool but couldn’t get it to work.
Anyway, besides going to the Dodge dealer, what is the best way to replace this line? It attaches to the front distribution block just up under the master cylinder, the ties in to another block on the axle with a rubber line. Need to find a shop I guess with some long solid lines. 3/16” I think.
