Smoke Control for A 24 Valve
- Replies 12
- Views 2.9k
Mopar1973Man 3 posts
Greenlee 3 posts
Me78569 3 posts
rogerash0 1 post
Popular Days
Quadzilla adr and done. I passed emissions at 7k' with ~200 hp injectors. You can set your own timing gcurve or leave it stock.
Tunes https://mopar1973man.com/forum/182-quadzilla-v2-custom-tune-repository/ The quad shows you what timing is being commanded. The quad does not adjust timing at id
I'm driving a 24 valve with a Blue Chip Special X VP44 that has the timing slightly advanced to give it 22 additional HP. I also have a set of 75 HP injectors from Dynamite Diesel. They had to be readjusted to reduce smoke. I would like to use them but I need a way to control the smoke or fuel. I see a lot of members are using programmers or tuners for this reason. I'm not trying make a hot rod out of it just looking for a little more performance especially at lower speeds. With the timing advanced I have been told I can't use a tuner that has the capability to advance timing any more than it already is. I don't think with the 75 HP injectors I am going overboard and need special head bolts or springs to continue driving it. I wear leg braces and speed shifting is out the window. Some of the tuners on the market are pretty high priced. Any suggestions would be appreciated. Thanks
