- Replies 26
- Views 8.3k
Mopar1973Man 7 posts
Mike wolf 7 posts
dripley 6 posts
JAG1 2 posts
Mine goes thru a prefilter then the primary filter on the AD. It then goes thru the stock filter. I still stay between 14 to 20psi. I assume your pump is a DDRP which may not be capable of keep that p
Get one that goes to 30 psi. The shoot for between 14 and 20 psi at all times.
Yes I'm going to replace it with one that reads higher..
Ok guys a have a 2001 dodge 2500 diesel. It has 210,000 miles on it. Replaced the vp44 and put a fass lift pump on it 1 1/2 ago. About 2 mouths ago I was going down the highway and put it to the floor and it died on me. Would not start back up so I had it towed home. Late that day I try to restart it, it took a long time to get it started and it sounded and run like Crap. Like it was running on 2 or 3 legs. Towed it to dodge dealership. And they told me it was the injector pump. So I had it towed back to my house and order a new injector pump and put in one. But it is still running the same way. Like crapp.. I even try putting on a new ecm. But it still run like crap.
Here are the codes I'm getting.
P0122
P0253
P1689
P1688
Please help me if you can
Thanks
Mike w
