- Replies 48
- Views 7k
rjbest333@gmail.com 20 posts
Mopar1973Man 15 posts
dripley 6 posts
Dieselfuture 4 posts
If you can't get it started using the BC hot wire method the VP44 is done. Just wanted to be clear about what it takes to start sometimes being that some people might be giving up too eas
The one thing I reccomend is snugging your cross over tubes/fuel lines into the injector before torquing the hold down on the injector.
There is a delay relay mod or you can actually buy a relay with a built-in delay already. Sounds kind of confusing I know. But if your truck starts with half a crank like it should, there really
Hi Guys, I was directed here from BigFish over on the cumminsforum.com
My 01 won't start at all. For the past few weeks it was not starting back up once HOT. I pulled the fuse to the lift pump to see if it would then start when hot, to eliminate the possibility of a diaphragm issues in the vp44. It would not start. It did start the next morning and threw the code P0118, coolant temperature sensor. I replaced that sensor, and everything seemed fine. IT would start back up when hot after replacing that sensor.
Then a week later at the diesel station, it did it again. Would not start back up when hot. I waited 20 minutes, and she fired right up. I drove her home. The next morning she fired right up, drove 200 feet and stalled dead. Then started right back up. I checked for codes again, and only P0118 was there, so I cleared all codes and now she won't start at all. Yes she cranks at fuel speed. Yes the WTS light does come on, and I can hear the grid heater click off when the light goes out.
I've cleaned all battery connections, replaced one battery that was weak, checked all grounds I could find, cleaned the connections in the PDC. I had the alternator tested and all the diodes and the rectifier is fine, so I know that didn't knock out the ECM. The truck is out of Florida and very clean. I even bled injectors 1 & 3 in case there was in there somehow and fuel came out immediately. Of course I changed the fuel filter right after this first started a month ago. I put a FASS lift pump on about 800 miles ago back in July as she had the retrofitted pump in the tank. I also bought a new MAP sensor and put that in. No avail. Not sure where to go or what to eliminate next. Any help would greatly appreciated. I'm a campgrounds in Rhinebeck NY for the summer with my camper If anyone knows of any diesel Guru's around here. Hoping to leave in a few weeks and willing to pay for expert help.
