LED lighting - Interior lighting
- Replies 41
- Views 9.1k
Mopar1973Man 18 posts
Marcus2000monster 7 posts
portlandareae28 5 posts
dripley 3 posts
If you are missing all that stuff, there is a harness with new switches you can get on Amazon for $35. It's for the overhead console without the data display but it can still be used though. I just
The switches have probably come apart. If so they can be glued back together. Had to do both of mine about a year and a half go. Not hard to do. I used some gray silicone others have used super glue.
Before, stock OE lights After, Super Bright LEDs
After having to dig through my truck attempting to fix the dome light and the power mirrors. I noticed the light socket was rather burned not melted but that darker burn mark from the heat of the old-school bulbs. I went out to superbrightleds.com and ordered me a new dome light blub and a pair of map light bulbs being winter is coming, daylight saving time will go away and it will be dark in the cab for morning and evening travel. It would be nice to have a bit more light and without burning up the sockets.
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/921-led-bulb-15-smd-led-tower-miniature-wedge-retrofit-car/910/11267/
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-5-smd-led-tower-miniature-wedge-retrofit-car/206/6774/
Let's see how these work out. They should be here by about the 20th of the month.
