- Replies 7
- Views 2.3k
dripley 3 posts
KOYOTE 2 posts
Mopar1973Man 1 post
AH64ID 1 post
a while back my truck went bezerck. surging, little or no throtle response, cruise control coutting on and off, temp gauge swinging wildly from 0 to max and the engine was surging while indeling and me standing beside the truck. i was already having some dead pedal issues and had puechased a new vp44 from blue chip diesel. thinking that might be causing the problem i installed the injector pump with no change. I had multiple high and low voltage codes on the iat, tps, temp and map sensors. also had codes on the cruise control, tach, system voltage. did some test on the tps and replaced no change, replaced the temp sensor no change, clock spring nochange, speedo(on board diagnostic said it was bad) no change. I cleaned and reconnected every ground i could find and checked the wiring to the sensors to the best of my ability and could not find any thing wrong. figured it must be the ecm and replaced. The surging and cruis control malfunction seem to have stopped. I still very little throttle response and the temp gauge pegs right after starting a cold engine. i connected a scan tool and erased the codes and the following is what i have left; 112, 1286, 1475, 563, 122, 343, 117, and 237. the scan toll showed the engine temp and air temp to be 293 degrees i guess thats why there is so little throtle response due to the enging thinking it is hot. i have checke the voltage to my tps, iat, map, and tps and all are around 5 voltsand appear to be functioning properly/ i recalibrated the tps with the pedal only did not know might have to adjust the voltage per the sticker on the back. i will do that when i get home. i checked resistance on the temp and iat sensors and they both seem to be fine. i did get a 606 code that i never had until replacing the ecm, but replacing it did cure a couple of my ills. i am not an electronics guy by any means but i am learning as i go. Has anyone encountere anything like this.
