- Replies 26
- Views 16.4k
2000Ram2500 11 posts
ofelas 6 posts
Mopar1973Man 5 posts
Marcus2000monster 2 posts
If you guys are using single turbo's, it would need a heavier spring than what's used on a compound turbo application. Judging by memory, go with a 60 to 100 thou coil wire thickness, and
I couldn't have said it better. I'd put a locknut on there too, once I got it adjusted to where I wanted.
The 20* elbow is the factory one. Some aftermarket ones are adjustable and some are preset. The one that come with my EZ is a preset one. Max boost with it is 32 psi. I plugged mine and it still has 3
Happened to stumble across this video on youtube over the weekend. Was wondering what everyones thoughts were. Looks pretty simple just not sure if there are any cons to it. Only thing that comes to mind right away is how does he plug the existing port for the wastegate?
