Low Air Flow and Smoke/Burning Smell from Vents
- Replies 5
- Views 2k
Mopar1973Man 1 post
dripley 1 post
Dieselfuture 1 post
Tractorman 1 post
Popular Days
Yes, they do and it is a worthwhile investment. The filters are washable, as well. I did my HVAC repairs one year ago and I did not want anything to be able to work its way into the ducts.
Since I bought the truck 5 years ago or so I have been dealing with poor air flow from the heater and A/C. In fact, it struggles to keep the windshield defrosted, especially with several people in the truck. Once in a while, usually after start up, I get a faint smell of something burning and I have even had smoke come from the vents a couple of times. The problem has been getting worse so I finally decided to pull the HVAC box and found what I thought I would. The evaporator is caked in leaves and other debris. I looked all over for where the burning was coming from and the only thing that I can see is that the blower resistor was covered in the same debris. With the resistor broke the conductors on the inside are exposed and I assume that they have been the cause of burning. There is nothing burnt or charred inside the box.
How do I keep this stuff from getting inside the box again?
I ordered a new heather core, evaporator, resistor, and blower since it is getting tough to spin. It ought to be much better than it was once I get it back together.
