Well, bad news post w-t mod.
- Replies 22
- Views 7.2k
Exalted85 8 posts
Mopar1973Man 7 posts
dripley 3 posts
JAG1 3 posts
PO500 is just loss of traction code. I get that all the time going up my gravel road because its not a limited slip differential. probably about a 15% grade. Don't forget to check the qual
So, as I feared, the truck is still struggling to maintain highway speeds with erratic engine load. Watch the video on 1080p..you can probably hear the truck revving and dropping, but even if not, you can watch the engine load on my obdii cell phone in the top left gauge (shout out to moparman for sending me his obdii gauge file a year ago) and you can see the needle all over the place trying to maintain speed. 0-52, 25-50, etc etc..it's revving hard, dropping, revving, dropping. She as it used to.
One curious thing I noticed while doing all that electrical stuff..is there seems to be a random wire, probably #18, going from a body mount in the front, grounding on the body in the same spot as a probably #8 ground coming off the driver side negative battery terminal. First pic shows location, second, you can see it heading into the apps loom. (I didn't know how hot that black plastic tube got, so I put some spare loom around the battery negative and the #18 wire)
Is this little body mounted ground to tps factory? It doesn't feel seem like it. Could this be part of the problem?
