Quadzilla on a stock truck
- Replies 61
- Views 21k
Me78569 18 posts
portlandareae28 10 posts
Mopar1973Man 8 posts
Marine 8 posts
It's not bad once you get your hands on it. If you want to see what it is like, download the app from the play store. Iquad by quadzilla. You can build your own tunes or import one
I passed a lug down emissions test with 7 x .012's at 7000' altitude rv275 will be a cake walk with a quadzilla. I would personally be going with 7 x .009's and a quadzilla. that will suppor
Peak power isn't what is important when you consider injectors. Bigger injectors will give you more useable power under the curve without smoke. So a stock injectors truck with a quad a
So since I am in California Smog country now. I want the truck to run the absolutely best it can. I may be able to squeeze RV275's in it, but not much more. Maybe a more efficient wheel in the turbo and thats that... unless there is a ball bearing turbo that is essentially stock that could be an option.. SO the question is I have an Edge Comp now.. I am not real impressed by it as the truck seems rough on the high tunes and it smokes like a freight train on the high tunes as well... So could the Quadzilla enable the power without the smoke? smooth/smoother idle? better EGT's? etc... I look forward to learning from this thread as I have not dug into quadzilla much yet.
