To increase my thread count and to post over here :) :postwhore:So the 3rd gen come with a common rail rather than vp44 ..... what else ?
  • Replies 8
  • Views 4.8k
The injectors are computer controlled individually. The transmissions are different. Axle ratios are 3.73 and 4.10 I think, rather than 3.55 and 4.10. Body is different, interior is different. Engines have all been the same basic block but with different fuel systems. The block might change a little through the years but not much. What specifically do you want to know? There are many obvious changes but I don't know if you want more details on how common rail works or what.
No.Kinda what you said.I knew the shape/style of body as well as the CR injection (ECM controlled delivery) was differentI figured there may be some emissions stuff depending on year ? But wasn't sure what elseIS the tranny a 48re for auto ? Anything else (major ) ?
It is a 48 re tranny. the frames are built stronger and are heavier. They have a bigger/ stronger t-case. they have amarican axles rather than Danas hence the gear ratio difference. No difference in exhaust related emmissions until the 6.7 came along with the dpf system in 07-08.
The price of 6 injectors on a 3rd Gen is more than a VP44 pump on a 2nd Gen... The failure point of the CR engine is from poor filter performance and damages the internal valve of the injector that controls injector firing. Typically the 3rd gen get just slightly less MPGs because of the multiple injector firings to make them quiet. 6.7L are worse with the DPF re-gen.
coolthats interesting on the axles/gears as well as the injector failuresyeah I was on cumminsforum and someone was like $2k for injectors - and I was like :stuned:Thought they were higher performance afterarket or something ..... but nope - CCR :Pnice.:thumbup2:
Some of this will be a repeat.Axles: AAM (9.25" FR, 10.5" Rear (03-04 some SO's), 11.5" all HO's, and all 04.5+) 3.73, 4.10, 3.42 08+Man Trans: NV4500 03-04, NV5600 03-05; G56 AD 05.5+, G56 AE 07.5+ (RARE in late 07's)Auto: Early SO's may have 47RE; rest run 48RE (OEM Exhaust Brake capable in 06); 68RFE 07.5+Xfer Case: NV271 Manual Shift, NV273 Elec ShiftTurbos: HE341 03-04; HE351CW 04.5-07; HE351VE (VNT) 07.5-currHead: 03-04 increased flow from 2nd gen; 04.5-05 better flow and better valve seats; 06+ changes to casting for swirl action of air, and IIRC minor valve seat changes.Injection; CP3 HPCR, up to 23,207 psi for 5.9, and 26,107 psi for 6.7.Lift Pump: Engine mounted crap till 05, then a quite reliable in-tank that still being used.Cab's: Quad Cab is streached to be a 3/4 Crew; Mega Cab is introdued in 06 (QCLB frame with a short box)Frame: Hydroformed (not sure if 2nd gen were)Brakes: 4 Wheel discs, large enough 17's must be used. Suspension: From what I can tell all CTD's have the same front spring rates, and they all have the same FAWR; Rear 2500 and 3500 SRW use the same base 4/1 leaf pack rated at 2600 lbs per pack. 3500 DRW has a 3/1 leaf setup rated at 2800 lbs per pack. Both SRW and DRW 3500's have a 2pack overload setup rated at 1400 lbs. FAWR: ALL 5200lbsRAWR: 2500 6000lbs3500 SRW 6200lbs3500 DRW 9350lbsEngine: 03-04 had 3 options Cali SO 235/460 (Auto or 5 speed)SO 250/460 (Auto or 5 speed)HO 305/555 (Auto or 6 speed)04.5HO 325/60005-07HO 325/61007.5-currHO MTX 350/610HO ATX 350/650Exhaust:03-04 were 3.5" DP, 4" MBE04.5-curr full 4"03-04 only Cali had Cat04.5-07 all have Cat07.5-curr use Cat and DPFEmissions:03-04 used the cam profile (in-cylinder style EGR, keeps some exhaust in the cylinder)04.5-07 used the same cam, plus a 3rd injection event, a different piston design, and a Cat to meet emissions.07.5+ uses an external EGR, DPF, Cat, 4 injection events, and lots of fuel to meet emissions.
We have a winner !! :) :thumbup2:Forgot about the brakes - I still have rear drumsInteresting on the engine options also - with SO/HO and CALI variation.thanks guysinteresting
Some of this will be a repeat. Axles: AAM (9.25" FR, 10.5" Rear (03-04 some SO's), 11.5" all HO's, and all 04.5+) 3.73, 4.10, 3.42 08+ Man Trans: NV4500 03-04, NV5600 03-05; G56 AD 05.5+, G56 AE 07.5+ (RARE in late 07's) Auto: Early SO's may have 47RE; rest run 48RE (OEM Exhaust Brake capable in 06); 68RFE 07.5+ Xfer Case: NV271 Manual Shift, NV273 Elec Shift Turbos: HE341 03-04; HE351CW 04.5-07; HE351VE (VNT) 07.5-curr Head: 03-04 increased flow from 2nd gen; 04.5-05 better flow and better valve seats; 06+ changes to casting for swirl action of air, and IIRC minor valve seat changes. Injection; CP3 HPCR, up to 23,207 psi for 5.9, and 26,107 psi for 6.7. Lift Pump: Engine mounted crap till 05, then a quite reliable in-tank that still being used. Cab's: Quad Cab is streached to be a 3/4 Crew; Mega Cab is introdued in 06 (QCLB frame with a short box) Frame: Hydroformed (not sure if 2nd gen were) Brakes: 4 Wheel discs, large enough 17's must be used. Suspension: From what I can tell all CTD's have the same front spring rates, and they all have the same FAWR; Rear 2500 and 3500 SRW use the same base 4/1 leaf pack rated at 2600 lbs per pack. 3500 DRW has a 3/1 leaf setup rated at 2800 lbs per pack. Both SRW and DRW 3500's have a 2pack overload setup rated at 1400 lbs. FAWR: ALL 5200lbs RAWR: 2500 6000lbs 3500 SRW 6200lbs 3500 DRW 9350lbs Engine: 03-04 had 3 options Cali SO 235/460 (Auto or 5 speed) SO 250/460 (Auto or 5 speed) HO 305/555 (Auto or 6 speed) 04.5 HO 325/600 05-07 HO 325/610 07.5-curr HO MTX 350/610 HO ATX 350/650 Exhaust: 03-04 were 3.5" DP, 4" MBE 04.5-curr full 4" 03-04 only Cali had Cat 04.5-07 all have Cat 07.5-curr use Cat and DPF Emissions: 03-04 used the cam profile (in-cylinder style EGR, keeps some exhaust in the cylinder) 04.5-07 used the same cam, plus a 3rd injection event, a different piston design, and a Cat to meet emissions. 07.5+ uses an external EGR, DPF, Cat, 4 injection events, and lots of fuel to meet emissions.
AH64ID beat me to most of it..............heck, almost all of it!!!!!!!:2cents: I had a '99 regular cab, long bed before my current truck. As much as I loved that '99, my 04.5 is twice the truck and is way more "refined" IMHO. Sorry 2nd gen guys!!!! Quieter, better ride, way more power, just to name a few things. All that said, these 3rd gens go thru front end parts faster than the 2nd gens. I don't know if it's the Dana vs. AAM thing or not...............or just that the parts are made crappier now!!!!!??? Believe it or not, my 04.5 actually gets.......on average.......better mileage than my '99 did. My old '99 is now my folks truck, but I always make a point to drive it when I go down there.
