Traded for a bit of a basket case
- Replies 20
- Views 4.9k
Puller810 10 posts
pepsi71ocean 5 posts
Mopar1973Man 2 posts
dripley 1 post
I would check your line pressures first before assuming. You may find that you can extend your trannies life a bit by raising it. Here's the article I wrote for it.
Little update, built a tune for the truck using some base settings from Quadzilla. Drivability is much nicer. The lock/unlock thing is still there however it's not near as bad so we've made some headw
Needed a quad cab, so I traded my old single cab for a 2000 24v auto with issues.
I've read on the dead voltage gauge issue (mine has it). I've replaced the alternator, batteries, cleaned the grounds on the fender well, frame, batteries, front core support and the issue still remains. Previous owner had an alternator that was internally regulated as it only had the power wire going to it and it charged but the gauge didn't work. I replaced it with a new factory alternator and now not only does it not show voltage on the dash, it doesn't charge. Easy checks to hunt down the issue?
2nd issue, I have the tq converter lock unlock syndrome. Its constant, unless you are very steady on the pedal at hwy speeds. So far I've rerouted the ground wire away from the alternator and wrapped it with tinfoil. No change, the transmission shifts through all gears as it should. It has a triple disc converter and the trans has about 10k on it. Any suggestions on this? I know this stuff has probably been answered and I've done a few hours of reading which lead me to the things I've tried. Hoping to get a game plan together for the weekend and dig into it a little further. Someone has been into the wiring before as I spent a few hours redoing poor connections with soldered ones. Thanks in advance!
