- Replies 8
- Views 1.7k
Me78569 3 posts
Ravewolf 2 posts
Mopar1973Man 1 post
dripley 1 post
Popular Days
Buy a Subaru, they are good cars !
You are are not spamming up any thing. Asking questions and sharing answers is what we are about here. These trucks can be very reliable, it just takes some effort. All depends on what you sta
243k miles on my last VP44. I'm at 362k miles now. 50k miles under warranty P0216 code lift pump failed no gauges. 243k miles and failed P0216 code stuck full advanced!
Ok, well, as some of you know, my trucks tcase pooped the bed on the way to my new job. It's home now, safe at my friends shop. I'm 900 miles away though, so I can't do anything but think about what I need to fix, what I should do, etc.
Now obviously the tcase is priority. Once that's fixed, she's good to go. But given that the last two times this truck has gone on a long trip and left me stranded, I'm leery about some things.
The truck has 265000 on it (I think). I think the vp is the original. Not sure if the previous owner had it rebuilt, or replaced, or anything. He said he had the transmission rebuilt, but that was an obvious lie. So I choose to err on the side of caution and believe it's the stock one.
I have a FASS titanium fuel pump, and it has a huge line going from the pump to the vp,and has push loc fittings. So I know it's getting fuel.
How long does a vp usually last? I also have bigger injectors (they're supposed to be 150s, they haze at idle when it's cold, and dump fuel like crazy, but I plan on changing them as well), and every now and then it idles funny (yes I know I need to monitor fuel pressure, that's coming soon) but no drive ability problems. When I had her on the road last, she ran real good,so I'm probably being paranoid.
Why? Because when I drive to work I have to drive some desolate and empty roads in cold snowy back country, and I don't trust the truck enough to chance driving if there's a good chance it'll leave me stranded. Most of those places have no cell service, so I couldn't call for help if I needed, and it gets cold. Really cold. It's literally a life and death situation at that point.
I'm seriously considering doing a p-pump swap to get rid of that possibility, but damn it's expensive.If the vp pump can make power and last, it's the cheaper alternative.
Lastly, my turbo is an aftermarket turbonetics unit. I think the specs are 65/63/.84, and it has no wastegate. Is this too big for a single? It doesn't spool until 2000, but it doesn't built steam until 2500-2800(i think), then it flies until the computer cuts fuel. It smokes like a freight train though. Like, alot of smoke. ALOT. It's fun, but laggy. I'm not sure if that's because of the fuel, programmer, or something else.I have an hx35, so I could compound it if need be.
I hope this isn't too much to digest all at once. But after two strikes, she's on my crap list. If something else happens again, she gets sold to the highest bidder. Then I'm buying something else.
