New ecm, no power at all
Hey everyone, new to the forum i have a 99 eclb. I put a new ecm in after signs of a failed ecm, while I was waiting on the new one I pulled the alternator out to test it to avoid the bad diode problem. So I figured id do the mod w-t wrote about with the regrounds and new alternator power wire and what not. Well cut to I finshed it all up put the new ecm in and hooked the batterys up and i got nothing? No interior lights,headlights and no power at all. I had batterys tested and they were good. Cleaned all of my grounds again made sure everything was hooked up .checked over the wiring a few times im clueless now, im not good at electrical diagnostics, any idea of where to start?  Thanks for the advice
  • Replies 70
  • Views 11.8k
  • Good to hear. I knew it had to be simple with all power gone. To all my friends here, I AM AN ELECTRICAL GIANT!!!!   Back off the soap box now, I need to check all the pennies in f
  • Do you have power to the PDC? Did you leave the short positive lead from the drivers battery to the PDC?
  • Chicken man's getting cocky now
16 minutes ago, Boondockboost said:
Could the pump straining make the wire melt?
Yes. If there is no fuse or too big of fuse.
2 hours ago, dripley said:
I believe he means cant and not can.
Yeah, typo.:duh:
Theres a 25 amp fuse, nothing changed on the setup that worked 2 weeks ago until the ecm now new ecm and this lol. I'm at a loss for it
The harness for my AD has only a 20 amp. I think the fass are the same. But if you have a relay harness for the pump the only thing the ECM pigtail provides is a trigger to close the relay and no power for the pump. The power for the pump should come from the battery, PDC, or any 12v source other than the ECM.
Where did you get the "new" ECM ?
New ecm is from all computer resources. Well I figured it all out and the truck runs great. I think the lp is on its way out its starting to show its age and has fared well this far. But I thank everyone one for the help. Happy its going again and running good with the new ecm
Well, what was wrong with it /
The lp motor was sticking and causing the wires to heat up I guess is how it was described by a friend who helped me out.
This new ECM from All computer resources was it still defective? Or was that resolved?
11 hours ago, Mopar1973Man said:
@Boondockboost Why Pepsi71 Ocean is asking is because he keeping the database of good rebuilder going. So your feedback will either place a rebuilder in the don't use list or thumbs up list.
I'm thinking I need to redo my table an order it from Positive, neutral and negative. and add in people from each category. Since this company on the list has 1 negative and one neutral now.
 It would be nice if more folks that have been thru this could add to your article. When mine went back in 2010 info was non existant. I never been so alone on an a vehicle problem in my life. The dealer and couple shops I spoke with were no help either. All they coild offer is we will read the codes and replace what was necessary. Unfortunately the ECM said everything was malfunctioning except itself. The 1st rebuilt I put spit out the failed ECM code.
 So any of you that can help @pepsi71ocean expand his article, please  help him add to it. It maybe to late for you but not others. Havingmthis back in 2010 would have saved me a ton of headache not to mention cash.
I was dam lucky that I had a friend on Facebook who ran a shop that found that had a reliable re builder. So for me I was spared the nightmare. and Of course Mike and I talked about this article for over a year before I was able to search and compile a list of companies.
The biggest advice I got was to check grounds. Cant even remeber how many times I was told that and that alone. Of course at the time I had no idea just how important the grounds are. This was the first vehicle I had that I even knew about trouble codes and i was not even an electrical midget back then but more of a put your tongue on it and see if its hot electrician.
I will definitely keep you posted on the ecm, ive yet to take it for a drive. As fas as the ground mod was super simple and now I'm just wondering if i should consider a 140amp breaker for the alternator lead?
UPDATE! well finally got to take the truck on a test drive after ecm and little problems. 15 mins of driving the truck i got the same misfire and smoking i was feeling before ecm replacement. ( I know the previous ecm was bad, I sent it to SIA electronics to have it tested). Now I'm getting p1693,p1694,p0230 and p0216. So back at it again hopefully gunna find sone answers
SIA? Can you expand on this?
Sure, SIA Electronics out of tildon,IL. You can send your ECM, they will test it and if repairable they will repair for 183$? I believe thr price was. And if its not repairable they send it back to you for shipping charge only. They also reman Mass Air Flow Sensors, Anti-Lock Brake Computers EBCM’S and anti-lock brake hydraulic units
http://siaelec.com
