New ecm, no power at all
- Replies 70
- Views 11.2k
Boondockboost 27 posts
dripley 18 posts
Mopar1973Man 9 posts
pepsi71ocean 7 posts
Good to hear. I knew it had to be simple with all power gone. To all my friends here, I AM AN ELECTRICAL GIANT!!!! Back off the soap box now, I need to check all the pennies in f
Do you have power to the PDC? Did you leave the short positive lead from the drivers battery to the PDC?
Chicken man's getting cocky now
Hey everyone, new to the forum i have a 99 eclb. I put a new ecm in after signs of a failed ecm, while I was waiting on the new one I pulled the alternator out to test it to avoid the bad diode problem. So I figured id do the mod w-t wrote about with the regrounds and new alternator power wire and what not. Well cut to I finshed it all up put the new ecm in and hooked the batterys up and i got nothing? No interior lights,headlights and no power at all. I had batterys tested and they were good. Cleaned all of my grounds again made sure everything was hooked up .checked over the wiring a few times im clueless now, im not good at electrical diagnostics, any idea of where to start? Thanks for the advice
