Optimum fuel pressure?
- Replies 20
- Views 4.5k
Mopar1973Man 9 posts
Blueox01 9 posts
dripley 1 post
Me78569 1 post
Popular Days
I have been running between 15 to 20 psi the entire 240k mile life of this VP. Only see the 15 psi at WOT. Normal driving i see 17.5 to 20.
15 to 17 PSI on the last VP44 for 243k miles... 1/4 of a million miles is pretty good in my book.
Lie... Doesn't exist in the Rev 027 pumps. Steel plate. Rubber diaphragm doesn't exist... Everything inside the VP44... Optimal Fuel pressure: 14-20 PSI. This ke
I copied this from Diesel Addict
" There is a diaphragm located inside the VP44 injection pump that is very sensitive. This VP44 diaphragm works best under pressures between 10 and 15 PSI. Some pumps will be able to run higher than that but Thoroughbred Diesel does not recommend it. After changing your VP44, if you notice continued hard starting or feel as though the pump is getting bogged down, it is probably time to check the lift pump pressure. Our recommendation for optimum fuel pressure is 12 PSI of the VP 44".
Reason I ask is because I replaced my manual FP gauge with an electric Auto Meter that has a warning light for to low/high fuel pressure. Plus I've read you should not have than 15psi max pressure, I have Raptor 150 that I can adjust FP.
Edited by Blueox01
