- Replies 16
- Views 3.9k
dripley 5 posts
Dieselfuture 5 posts
Mopar1973Man 3 posts
CTcummins24V 2 posts
Popular Days
Use rosin core solder for electrical connections. Acid core is for radiator repair and plumbing.
I've use plumber's flux before Edit Pine tree sap may also work
According to what I've read online, yes. Plumbers flux is some acid flux, electrical flux is called a rosin flux, so I've read.
I know little to nothing about wiring...Finally replacing my oem battery cables, need to attach new cable to existing ground on the passenger side with the grey plugs. I want to crimp and solder the connection, I already have rosin core solder wire, do I need to dip the ends in rosin flux to prevent corrosion? Or is the rosin core wire enough? I can’t seem to find rosin flux anywhere.
