05 gto/ cant leave the gm section open, im a fan
- Replies 8
- Views 4.4k
KOYOTE 3 posts
Mopar1973Man 2 posts
ISX 1 post
Rogan 1 post
this is sacraligious not to have any chevy post even though its a dodge site, so a seebee brought in a 05 gto 6 speed 6.0l, this is a sweet car got to perform a shake down before mods start it will scoot especially with trac control off:ahhh:. so 40 thousand miles absolutly no problems and he drops it off with over $4000.00 worth of hot rod parts in the trunk and asks can you install all this by fri. so it can be sent to the chassis dyno. i inspect the new trick flow cyl heads and lunati cam, injectors, fuel pumps, rockers, under-drive pulleys, yad yad. and say yea $1400.00 labor plus misc. parts thinking he would at least twitch a little or somethin. he hands me the keys and said make it happen.
sometimes my job is fun so got it all tore down today and will start building it up tommorrow, going to be a late night. hope to see at least 550 hp from the dyno, hope he realizes hes not going to drive to the dyno.
or run the risk of melting a piston:banghead: but i will explain before he departs from the shop. so thats a day in the life of koyote auto and the gm section is no longer empty:tongue: we are pleased!!!
