- Replies 15
- Views 6.1k
Towrigdually 7 posts
Chris O. 4 posts
Mopar1973Man 2 posts
Dieselfuture 1 post
This is from my CCD bus tool notes. When Monitored and Set Condition: REAR SENSOR OPEN When Monitored: Ignition on. The CAB monitors the wheel speed circuit every 7 milliseconds (ms). Set C
Ive replaced the rear sensor with a new from Napa and rock auto. Still no change. I can clear the codes and the lights go out momentarily then come right back on.
The fuses for the abs system are good also, as are the underhood connections, along with the connection at the rear axle the pigtail is in good shape.
the 74 code will come and go if I just sit with the truck running and scanner hooked up.
Has anyone else had these codes with similar issues?
Edited by Towrigdually
