Hey guys new here. Hope this is where I post this. I just got a quadzilla v2 and I am playing with custom tunes. But wanted some input on what would be a ideal dd and tow tune for the truck listed below.
99, 24v, nv5600, quadzilla v2, 95 hp industrial injectors, 1 stage above stock vp44 from industrial, fass 150, ats aurora 3000, vclamp 4 inch downpipe to 5 inch mbrp with 6 tip
  • Replies 9
  • Views 3.4k
  • Small to mid   Small: 50-95's mid: 100 - 150's big: 175 +   is my rule of thumb.    Load a couple tunes that you want. try them out, then come back with things
  • the quad reads boost from the ecm for 0-16 psi then from 17+ psi it adds on top of the ecm signal reading from the sensor itself.
thank you I have been looking at this page just wasn't sure where I stood on injectors small mid or high
Small to mid
Small: 50-95's
mid: 100 - 150's
big: 175 +
Load a couple tunes that you want. try them out, then come back with things you want to change or to be different.    Without a baseline for us to understand your wants it is hard for us to recommend something.
If you have been running other tuners make sure you put your foot in it with the quadzilla.  there is no maxing duration at low throttle input to give a false sense of power.
I have tried a few tunes and I liked them. I have been making a few and have found my manual boost gauge reads 5 psi higher than the quadzilla. So I've had to run fuel higher in CAN-bus. Only problem I have is a significant jump in power at 2000 rpm. I would like to make it more smooth power and not such a big jump. My guess is timing but not sure if i should run on the high side or low.
Power Levels:12
Timing
Fuel Load Timing: 3
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv: 2
Timing vs rpm
1500: 16.2
2000: 18.5
2500: 21.2
3000: 24
Timing Max: 25.9
Wiretap
Pump Stretch: 1400
TPS Pump max: 100
TPS Pump Min 15
Minimum Pump Tap Fueling Percentage: 0
Pump Low Boost Scale PSI:  30
Boost Scaling: 30
RPM Limit: 3200
Power Reduction:
0 PSI %: 103
1 PSI %: 104
2 PSI %: 105
3 PSI %: 106
4 PSI %: 107
5 PSI %: 108
6 PSI %: 110
7 PSI %: 112
8 PSI %: 114
9 PSI %: 116
10 PSI %: 118
11 PSI %: 121
12 PSI %: 124
13 PSI %: 127
14 PSI %: 130
15 PSI %: 133
16 PSI %: 137
18 PSI %: 141
20 PSI %: 150
22 PSI %: 150
24 PSI %: 150
26 PSI %: 150
28 PSI %: 150
30 PSI %: 150
datalog the run where the jump happens.  Export the log as csv and we can plot it and see what is happening.
you go from 1 % increases in the 0-5 psi then by 3 above that.  That might be the jump in power you feel.  It might also be that your wiretap psi min is set to 30, so when you hit 30 psi the truck would likely jump out of it's own shell.
Try lowering wiretap min psi to 10 psi
Timing wise you can run +3 up.
14, 17, 20, 23
What I'm liking is +4 up.
14, 18, 22, 26
You might want to just read my article on tuning...
Your power jump may be from 16 psi up, that's where qwad map takes over I believe, mine is kinda aggressive there too.
