Mopar1973man high idle questions
- Replies 14
- Views 2.4k
Mopar1973Man 4 posts
billhulbert 3 posts
Me78569 2 posts
Marcus2000monster 2 posts
Popular Days
So the high idle switches are discontinued then? I was planning to get one just to save wiring time tricking the sensors...
They were talking about a soft transmission line set that used to be available the @Me78569 used to make. The high idle kits are still available.
I recently installed the mopar1973man high idle kit and it has worked out great. But i have noticed once I turn it off and let the truck idle for a while it will idle up again to 1200 rpm. It this normal after having my 2001 flashed with the smarty due to it being programmed into the system now. I live in clearwater florida and the days i have noticed this have all been above 70 degrees. Do you guys and gals think I have an issue, operator error, or just part of the new system flash. Any help as always is greatly appreciated.
2001 2500 quad cab shortbed
24v cummins
47re tranny
6 inch lift with 35x12.5 tires
