No washer or intermittent wiper
- Replies 32
- Views 8.2k
Ronniemx3 11 posts
Mopar1973Man 7 posts
98whitelightnin 5 posts
Haggar 4 posts
I pack mine with a thin layer of axle grease to prevent oxidizing of the aluminum and make them easier to come back off in the future.
I know when I got my new wiper motor, it said something and instructions about cleaning a ground that can cause intermittent issues. I believe that ground is somewhere on the motor or buy it.
Ronnie, I have had them stuck before too.... Spray a bit of penetrating lubricant in there. With the lock in the out position, I use some small pry bars, and slowly and carefully put so
Well this morning it was pretty frozen i we iced the truck etc drove maybe 5 miles went to clean the screen using the washers but the wipers froze. now i only have wipers working on fast no intermittent and no washer/wipers when the washer button is pressed anyone had this issue? Is there a fuse for this part of the circuit?? Thanks
