Fuel knock or timing knock or something else?
Good afternoon everyone,
This past week my vehicle situation has changed and I have been driving my 99 daily.  Since I have not driven it much this winter in the cold I don't think it sounds right.  I can hear a knock or a rattle noise when driving it and think it is either a fuel knock or timing knock and hopefully not something else.  The noise does not increase with rpms, but it is there. I believe the injectors are stock with 174k miles and the truck has a Quadzilla XZT+ chip.  Both videos were taken with the chip in the "timing" setting.  I have turned the chip to the off setting,  the noise is there but faint.  I have included a couple video clips, what do you guys think?
https://www.facebook.com/510913837/videos/10157061274603838/?l=8449699577610092840
https://www.facebook.com/510913837/videos/10157061269128838/?l=5694756621128741884
  • Replies 62
  • Views 15.7k
  • Collinst15
    Collinst15
    Well today is a good day.  Got my 100hp injectors in the mail from DAP and found a Quadzilla Adrenaline local for sale.  I've flashed it with the most recent v2.7 tune from here.  Will be a few weeks
  • Dieselfuture
    Dieselfuture
    If you got v2tuning I'd say go with 7x10 vco set at 320bar
  • Collinst15
    Collinst15
    Just a little update.  Truck has been running fine with what I call a fuel knock.  it still sounds like above on colder days, but I hope to fix that in next few weeks.  I ordered a set of 100hp inject
Thanks @Mopar1973Man.  I've attached a pic of where truck idles at once warm. I think it is above 800rpm.  Going to verify with obdlink tomorrow.
Tim
Let's see what you report. Make sure to check the RPM with a fully warmed engine.
Well here is a picture of the rpm from the obdlink.  The calculated load value is all over the place at idle from 0% to 6%, but rpm is solid at 842rpms.
Tim
Mine idles around or a little below 850 with engine load dancing around 4 to 6%. Injectors getting worn out?
I'm sure they are bad.  I have new DAP 100hp injectors waiting to be installed along with an Adrenaline.  It should run better once I find time to install everything.
Tim
ECM is struggling to defuel enough to get the idle speed down to 800 RPM. It should dance back and forth above and below 800 RPMs with engine load never touching that low.
@Collinst15 and @Unreal Summit both sounds like your injectors are worn out.
Good evening everyone,
Just an update.  Spent today putting injectors in and deleting the factory lift pump from side of block along with installing new return lines.  Truck runs amazing now.  Idles at 750rpm with about 6-7% load.  The "knock" has disappeared and it has a slight lope to it.  Didn't get a chance to install the adrenaline, but can't wait to get that installed.
Something is wrong there. Idle is set for 800 RPM. If it's down to 750 RPM there is a problem.
Mike,
I read the rpm off my phone quick while it was idling, I may have read it wrong, but it idles between the 2nd and 3rd line below the 1k mark on gauge.  It def idles lower than it did with old injectors.  I'll get another reading tomorrow morning.
Tim
Took truck for a drive to warm it up today.  Once warm it idles in park around 750.  I have attached a video of it idling.
Edited by Collinst15
Video added
I installed my new stick injectors Saturday and truck ran sweet until this morning it developed a knock. Any guesses? I have fuel leak somewhere I have to chase today but I don’t think it’s a high pressure leak cause I can’t see it on the lines and it’s coming from the back.
That is what my truck sounded like and I hated it. Sounds awe full.
Need to see live data tool that tach on the dash isn't all that accurate.
@Mopar1973Man I'll get a screen shot from adrenaline once I drive to work this afternoon.  I just got quad installed yesterday.Truck runs a lot better with 100hp injectors.  It used to fall on its face once in od and lose boost.  Now once it gets locked in od it takes off and boost goes from 10-20 quick.
Tim
If you are running a tune setup for stock injectors larger injectors could create a fuel/timing knock.  Performance injectors have a lower pop pressure (sometimes) so they can act like a worn out stock injector if they are adding fuel too soon.  At least that's the way I understand it. Somebody else will probably jump in here with a better explanation.
Here is a screen shot of readings from quad.  Truck idling in park just below 800rpm.  Don't mind oil pressure, pretty sure I need a new sensor.  I am going to keep it on stock setting for about a week and data log truck to see where timing sits before I start to play with quad.
Tim
Here is where I'm at...
NOTE: -50°F on Quadzilla to match my ISSPro EGT gauge. Then +1 MPH to match my GPS and cluster.
Running down I-84 in the trucker lane at 70 MPH with traffic. Remember I'm running 320 bar on pop pressure. 7 x 0.010 injectors and ARP studs. Shocker to pull EGT's down to just below 600°F in EGT's at 70 MPH.
My only complaint is EGT's can get a little high.  I get out of out when I see 1k, but once TC locks up egt's rise from around 700 to 1k pretty fast.  I do see anywheres from 20-25 psi of boost.  I have a stock hx35 and a boost elbow.  I did a WOT pull yesterday and saw 30 psi and egt maxed out at little under 1100.  I did rebuild a hx35 turbo cartridge and was going to swap it into truck as current hx35 is leaking a little oil. Now I am thinking I may need to jump into a bigger compressor wheel, but I have not loaded any custom tunes as of yet.  I am hoping egt's come down once I change timing and fuel.  All in all, I am very happy with the 100hp sticks and looking forward to playing with the quad.
Tim
You'll have to load a tune.
The default tune is based on stock injectors, not 100 HP injectors so timing will have to change.
