- Replies 29
- Views 5.1k
Mopar1973Man 12 posts
int3man 6 posts
Brubro67 4 posts
SilverMoose 2 posts
NAPA heavy duty flasher. That's it.
Napa Number - EP-27L https://www.napaonline.com/en/p/NF_EP27L Full article here with all the info in one spot.
I swapped out all of my interior and exterior lights on the Ram to LEDs including projectors, high beams, dash, climate, cab, fender, etc. I bought new headlight and taillight assemblies since the he
Now I've gone to the exterior lighting.
The left bulb is a switchback bulb for the front marker / turn signal. It's a white light on parking lamps but amber on the turn signal. Then the bulb on the right is a standard red tail light blub. Both sets are above normal lumens.
Front amber
https://www.superbrightleds.com/moreinfo/tail-brake-turn/3157-switchback-led-bulb-dual-function-60-smd-led-tower-a-type-wedge-retrofit-car/1916/4478/
Rear red
https://www.superbrightleds.com/moreinfo/tail-brake-turn/3156-3157-ck-led-bulb-dual-function-27-smd-led-tower-wedge-retrofit/3557/7523/
