- Replies 10
- Views 2.1k
JAG1 3 posts
dave110 2 posts
Dieselfuture 2 posts
IBMobile 1 post
Popular Days
Yes that is normal. After no electrical activity the latch will turn off (about 30 min.) You can check this by opening the driver side window and walk away for a 1 hour (it may be as short as 30 min.)
No, IIRC that is the normal operation for the belt to be free for a while and then the solenoid in the seats will discharge and lock up until you open the door again.
Wondering that as well. Maybe wipe it down with a greasy CFA wrapper?
When I pull the IOD fuse I hear a click where the seat belt lock is. At that point the seat belt is locked. When I put the IOD fuse back in there's a click and then the belt is free. So in other words it takes power to keep the belt in the free position. Is that normal? Seems that would be a drain after a while. My truck usually only runs on weekends.
Edited by dave110
