- Replies 9
- Views 3.5k
Ravewolf 3 posts
Tractorman 2 posts
Dieselfuture 1 post
NIsaacs 1 post
Popular Days
This is good information. I don't think the problem lies in the following: * pilot bearing (since it is not in operation with clutch pedal released) * clutch release bearing ( if i
When you drive things on with a hammer you taking a chance of cracking stuff especially a bearing. I would point my finger first at that.
I also had a similar experience but mine ended in a way that was obvious what the problem was. I could hear and feel an occasional screech and shake. Then one day a really loud screech and then soun
Alright, so she's back at it again. Probably my fault this time. Any who, on the way back from North Dakota a few days ago, I was outside Pueblo when I heard what I can only describe as a bearing seizing. A loud squalling like noise that shook the truck, and I felt it through the shifter. It wasn't constant. Just a quick noise, then gone. After everything that's happened, I was on red alert. Turned off my stereo, and kept driving, listening. Found an off ramp, and pulled off to see if anything had froze, was leaking, etc. Nothing. So I jumped back on i25 and headed south. She did it again. Loud quick noise. At this point I prayed nothing seized up completely before I got to Colorado City. Made the noise two more times before I got to the exit. I called some relatives to come get me and parked the truck at the truck stop.
I thought it could be the throwout bearing, but while I was waiting I kept hitting the clutch to see if it made noise. Nothing.
My thoughts are the carrier bearing I put on (we used a pipe and a hammer since I didn't have access to a press, and there's no driveline shops here, and it popped out of the rubber), or could it be the pilot bearing? It wasn't constant, off and on. Thoughts?
