Need to ground my tool box.
- Replies 12
- Views 10.2k
IBMobile 4 posts
Sycostang67 3 posts
Mopar1973Man 1 post
trreed 1 post
Sorry, I'm of no help with your issue I just wanted to say thats a nice toolbox. Sure beats my Harbor Freight special. I really need to upgrade...
Ground the top box with the green 14AGW wire run to the bottom box caster mount bolt. Ground the bottom box with the green 14 AWG run to GFI outlet ground. Drill hole large enough in face plate to
Well errr OK. I thought that's what the 3rd round pin for was grounding. If the cord inside is the green wire is attached to the toolbox metal then just plugging in the plug should ground the box. Hav
To celebrate not owing thousands of dollars in taxes this year, the wife let me use some of the money I had saved to get a new tool box. It has electrical outlets and a drawer for charging power tools. Apparently I have to ground both halves of this thing. I have already purchased the required wire and the instructions tell me where to attach to the tool box. I need to know where to attach the other ends of the wires. I have seen people run ground wires to the screws holding the outlet trim plates on before. Is that safe to do or should I run the wires into the outlet and to the ground wire in the wall?
