Qaudzilla woes
Well finaly got my qaudzilla back. They replaced the circuit board and sent a brand new wiring harness.Reinstalled it last night and now have some different issues. First off i now have a whining noise at all times that follows engine rpm. Second my truck idles a bit more rough with it installed and when free revving the engine at about between 1k and 2k rpm there is a dead spot in the rpm band. i can stomp it at idle and it will just drop out and come right back. When returning the tune level to zero it idles and revs perfect. Wht the heck is going on? This is stock v2 tuning as well. Havnt started the custom stuff yet. The rpm issue also does it under load. I will get on it and it will hesitate a tiny bit and go again. Please help. Thanks
  • Replies 146
  • Views 22k
  • Step #1, is to understand the tuning.  you need to read the below article and understand what the tuning variables do.     If you are not willing to put in time to tune your truck, then it
  • Don't play with wiretap until you get your canbus fuel map adjusted properly.
  • They abandoned Tfarao's truck, it was still stuck on lvl 1 when he got it back.   I can't remmeber much about it, but I think tyler said it wouldn't do more than 10-20 mph the way it was.
Did you update the Quadzilla box to current software? I would suggest making sure the new board is up to date first.
There is no free rev fuel table. The timing is not designed to free rev. Simple solution, don't free rev the engine. Might check the fuel table for a slider that is smooth in the curve like one that is bottom out.
Now make sure your APPS is actually making it to idle state. When the APPS is at idle state the ECM is direct control of the idle speed and the Quadzilla is ignored. Quadzilla should not come to action till after 1,000 RPM.
How do i check for updates?
That is rather strange for it to be normal to just cut out when revving. I dont like that at all. Does your truck do that?
The apps always falls back to zero % at idle is this what you mean?
Also my truck has been eating map sensors. Last one from napa lasted a month. The one before from cummmins lasted 6 months. Thinking theyre is a deeper issue.
The current release of the flash update.
Yes. Because there is no free rev fuel and timing table. Free revving needs a fairly steep timing curve to do it. Quadzilla team didn't see a reason for free timing table and left it out.
Well, that is half of it. The other half is the IVS switches. (Idle Validation Switches) will ground when they are in their particular mode. The idle state will ground the idle leg and then flip-flop and ground the throttle pin when not in an idle state. Typically I check by my exhaust brake or high idle kit for that. If the exhaust brake works then the IVS is hitting the idle state. High Idle is the same way if the IVS is in the idle state then it should engage high idle modes.
Live data tool will show IVS state correct?
No. The only tool that would is the DRBIII tool from the dealer.
I'm going to say start with the update. We don't know what version you are starting from. This just levels the playing field. I'm going to bet the APPS is fine but the flash is old version on the Quadzilla.
you should always have the ablity to flash your box.  however it isn't causing your issues.
1st, don't free rev.  it serves no purpose and there is no maps in the quadzilla as it is not important.  Tune on the road.
2nd the quad doesn't do anything at idle state unless you have quadzilla high idle enabled.   Since you have oem high idle, dont enable quadzilla high idle.
tune your truck, the base tune is not meant to be a great tune, it is meant to be safe across the board.
What do you mean whining noise?  Is it coming from your speakers or is it mechanical?
It has to be mechanical. Follows engine speed.
My box didnt come withb an update cable is it a common cable or special order online?
its a standard mini usb.
I dont see how a mechanical whining noise could be related to the quadzilla.
https://www.amazon.com/UGREEN-Charging-Controller-Players-Receiver/dp/B00P0GI68M/ref=sr_1_1_sspa?crid=1E3VLKQW3QHPF&keywords=mini+usb+cable&qid=1552062277&s=gateway&sprefix=mini+usb%2Caps%2C251&sr=8-1-spons&psc=1
Unless this is the first time he really heard the turbo spool. (Just kidding...) :lmao:
I'm having this weird thing going on with my 01. It happens I believe on all my tunes, but definitely when I'm on @Me78569 big injector daily tune and the performance tune that if I'm above power lvl 2, in second gear accelerating, it'll be going fine, then it's like fuel hits it all at once and not really stutters, just gets louder... If that makes sense? Anybody know what that is?
Gotta be something with your timing tables?
data log the issue.
data log the issue.
data log the issue.
If you ANY issue with your tune, datalog it happening and look at the log.
Another thing to point out is levels of power.
Level 2 is only 0 to 100% fuel no added fuel above stock.
Level 3 is only CANBus fuel table.
Level 4 is Wiretap on up which can be divided up for as many levels up.
16 minutes ago, Me78569 said:
data log the issue.
data log the issue.
data log the issue.
I haven't played with that feature but I definitely will, didn't even think to try that...
It should be your first stop.  It is a hugely powerful feature.
Also I would not be using a "big injector" tune on a truck with 7 x .009's    the big injector tunes are designed for 200 + hp injectors
@TheGreatWhite You might want to read over this too.
Might edit that up and define what a big injector tune really is... Suggestion.
I thought it said it was for 7x.009 as well...? Could have sworn it did.....
There are 4 different large injector tunes I see, they all say 7 x .011 or bigger
What tune are you running?
they show injector size in the description currently.
I apologise, I was in a hurry and threw down "big injector" when I meant "bigger." I'm running your "mid injector" tunes.
Edited by TheGreatWhite
