NV4500 Swap, need help!
- Replies 5
- Views 3.2k
Mopar1973Man 1 post
98whitelightnin 1 post
Dieselfuture 1 post
kzimmer 1 post
Hello all, this is my first post here on the forum. I've scoured this forum as well as a few others for existing diagnosis and can't seem to find a sure answer for my problem. I just purchased a 2000 Dodge 2500 24V that has had a NV4500 swapped in. Everything, but the cruise control, functions as it should, however, the check engine light is on due to the PCM still searching for the Auto tranny. Being that it won't pass CA emissions testing with the engine light I could greatly use help determining the simplest solution to my problem. I do have a Smarty programmer for the truck and the PO tried their "manual recovery" software to no avail...apparently he was told this only works half of the time? So here are my questions,
Would a PCM swap from a manual truck do the trick?
If so, what years of these trucks have compatible PCMs?
I've read of people reprogramming them to a manual truck VIN, but don't the ECM and PCM need to have the same VIN programmed to communicate properly?
Thank you in advance to anyone who can shed some light on my issue! If you feel this has already been addressed elsewhere, please, point me in the right direction.
Edited by MoparMatt
