- Replies 11
- Views 3.1k
Mopar1973Man 3 posts
Lucky2209 3 posts
LiveOak 2 posts
KOYOTE 1 post
OK I've put a Timbo APPS on and a noise isolator. That took care of the check engine code, however, it is still turning over a while before it wants to fire. Sometimes I have to crank it 2 or 3 times for about 3-4 seconds each time before she fires. I don't have anymore codes going off. I'm thinking that it is losing its prime of fuel. Could the airdog 150 be causing this? Before the sensor went bad it was starting fine, suggestions??
