- Replies 13
- Views 5.5k
JAG1 4 posts
Mopar1973Man 3 posts
IBMobile 2 posts
hdpwipmonkey 2 posts
Actually, its 7 to 12 PSI is an optimal cranking pressure range. Above the 12 PSI, it could produce hard starting because the timing is over advanced during cranking. About a one pulse
From the 2001 Ram FSM page 14-79: Normal current flow to the pump is 12 amperes. With the engine running, the pump has 2 modes of operation: Mode 1: 100 percent duty-cycle with a minimum pressure
Not possible. The solenoid low current side is only ground to the PDC. The high current side is only between the grid heater and the battery. The solenoid low current side has no contacts and low curr
I read somewhere that fuel pressure has to be 7-9 p.s.i. for the engine to start and higher pressures will cause a hard start condition. I also read the ECM controls this by rapid on/off pulses in the circuit to slow the lift pump pressure down for easy starts. After the engine is running the ECM knows to keep a steady voltage to power the lift pump or in our case, to trigger the relay used to power the lift pump off the battery.
If this is true shouldn't we be changing the lift pump relays more often, often enough to keep the contacts in new condition? As I understand it, the constant use of a relay has a greater chance of poorly connecting, burned contacts from frequent arching between the contacts on every open and closing.
