airdog and fuel pressure sensor location
- Replies 6
- Views 2k
Mopar1973Man 2 posts
Evan 2 posts
dripley 1 post
015point9 1 post
Popular Days
I'm pretty sure is post filter... Being the flow map is... Inlet -> Water separator -> Pump -> Fuel Filter -> Outlet
I have run the same set up 8 or 9 years myself. Different gauge though.
That's a gauge out of a fuel tester kit I bought when I was trying to figure out why my 2001 expedition had no fuel pressure. That turned out to be the anti theft system was enabled. And had to
seeing that surging can be an issue would putting my sensor in the air dog sensor hole location be a good idea? or would this be to far back? mine is located under the drivers door on the frame.
