2010 T Steering Drag Link Adjusting Sleeve
- Replies 11
- Views 3.2k
Evan 4 posts
Mopar1973Man 2 posts
Dieselfuture 2 posts
CTcummins24V 2 posts
I wouldn't worry about it being the weak link the whole bar is hollow tube anyway. I used my original pitman arm no problem, as for rotating the sleeve it will rotate just fine just loosen the clamps
I feel that way about Luke's links. Bandaid on shitty joints. I agree the scissor steering does work. Mines still on at 292k. But it wont be going back on when there are better options whe
I took out the heavy duty lift coils and put my stock front coil springs back in. With the lift, the drag link adjusting sleeve was maxed out with the threaded ends butting each other in the sleeve. So I cut 3/4” off each threaded end so they wouldn’t bottom out. Now I have a huge gap between the threaded ends with everything roughly aligned by me. Is this a weak point or don’t worry. This is on my 01 with 2010 T style steering.
