Hi I have a strange problem that I have noticed since installing my quadzilla.
Since installing my quad I have noticed my TC lock up is lazy and doesn't lock up really unless I'm climbing a grade and pushing the pedal a bit harder. Or I'm wide open in OD it will lock up..
Turn the quad off I get 'normal' lock up in 3rd and OD. Anyone else come into this issue before? Best way to over come?
Mystery switches are they worth it? I don't tow I just use this truck for fun it gets used a couple of times a week.
I have a bullet input, triple disc modified OD with more clutches etc (firepunk comp 2 rebuild kit without the billet intermediate shaft)
Looking forward to hearing if anyone else has noticed this issue I'm having
This is partial because the Quadzilla changes the amount of throttle given to hold road speed. Just changing your fuel map will change how the transmission see throttle. If your tune is heavy fuel the
Cheers
