Hvac defaulted to defrost
- Replies 26
- Views 5.7k
dripley 10 posts
Dieselfuture 6 posts
Mopar1973Man 4 posts
IBMobile 3 posts
There is a connector to the right side of the fuel peddle, half way between the ash tray and fire wall. Check the vacuum hose connectors for rot.
My thinking is it ru s straight to the connector at the throttle then to the selector. If thars the case then I am going to run a new line from drivers side thru the firewall and to the selector if al
It should run directly to the selector. then it goes to the three motors.
As the title says all my heat and ac are going to defrost. My vacuum lines are all connected and I have vacuum at the pump, at the 90 on the fire wall and at the 90 that turns into the firewall to the hvac. I do not have vacuum at the switch. I cannot seem to find a pin out, for lack of a better term, for the connection to the controls. I am assuming the black tube is the one supplying vacuum to the controls. Not sure that matters since I can feel no vacuum at any point on the connector. I am seriously thing of capping the line at the passenger side firewall and just bringing a new one thru the driverside straight to the connector. Does any one know if that supply line connects anywhere else before it goes to the controls? Or does any one have a map of the HVAC vacuum lines?
