Fuel Pressure Isolator
- Replies 11
- Views 3.2k
Mopar1973Man 5 posts
Haggar 3 posts
Dieselfuture 1 post
Bullet 1 post
I run diesel straight into the cab with no problems...via snubber and needle valve like Mopar1973Man says. Gauge has always read perfectly with very little if any water hammer.
Mike, Unless you have a leak, there is no flow on this line. I expect that some of my fuel from 5 years ago is in this line. The only change in that line is due to thermal expansion and
That's a great point. If you install your snubber that close to the vp, it could see flow. I chose to install it near the sensor, so other than bleeding it will never see flow, only pressure. So it
I am still running a isolator on my fuel pressure gauge and I don't think its reading right. I remember some sort of needle valve, is there a brand or size I should look for ?
