- Replies 191
- Views 40.9k
Evan 87 posts
pepsi71ocean 35 posts
Mopar1973Man 21 posts
Me78569 18 posts
Rather than spending ~$600 on head studs, you should sell the s03 and put $400 of the $600 that you would spend on the studs to a quadzilla. 3x the power and you can tune timing to not blow the head
Good drawing! It reminds me of the crazy/hot matrix. A must see for us dudes...
I would warn against being too throttle aggressive down low with a S03, it does not pull timing at heavy throttle low RPM which can result in head gasket issues. The chance is higher since you have a
Rolling through Craig's list see a s03 for 250. It's an older add he says he still has it. I'm like ****.
I ask if I can take the programmer for a spin. Get it loaded on 9 and he rides with me. Get out on street and stand on it , I'm like **** I wasnt expecting that. Hes like what turbo is that it whistles he thought it was something cooler then a stock hy35.
Pretty much roll around the block. Pay him and we go on our merry way.
7x09 injectors + s03 = fun
Edited by Evan
