cheap air compressors
- Replies 19
- Views 6.5k
KOYOTE 4 posts
Mopar1973Man 3 posts
ISX 2 posts
edcasey 2 posts
ahhhhhh!!!!!!! me and my dog came in to the shop to install onboard air on my dodge today and i spent the better part of the day installing air compressors in the tool box, holding tanks in and under the bed, wiring up sensors and pressure gauges. figured i would check the system out before installing quick connects on the bumpers front and rear, found and repaired a few leaks and watched the pressure build and all of a sudden i blew a fuse on one compressor, checked wiring and cooled off unit tried again and pop. this sucks then found second compressor leaking at head gasket. well i guess thats what i get for installing cut-offs from a mini truck. oh-well guess ill do a right up on disassembling and rebuilding air compressors if i can find parts.
