Front Brakes
So I heard the standard grinding screeching noise under a stopping yesterday.  Looked at the front brake pads and they are shot.  Went on RockAuto for a new set of pads and rotors.  I noticed a lot of different options.  Prices ranging from 25 each for rotors up to 250 for the top end.  Is there a substantial difference between the low end, mid grade and top end?  I don't pull heavy loads, just daily driving to work.  I'm of the school of thought that you get what you pay for.  I just hate to waste money if its not really any better.  I know the pads are substantially different depending on application but the rotors are my real question.  Whats everyone else running, recommend, certain things to stay away from?  Any certain combination that works better than others.  I live in Montana so we don't really have major corrosion issues.
Thanks
Bill
  • Replies 50
  • Views 10.1k
  • I ddi mention I bought mine for towing, just assumed everyone would know that it is best used for down hill and not up hill.
  • Cronus577
    Cronus577
    If your truck is a 2001 or 2002 4x4 I would recommend upgrading to the third gen brakes. Made a huge difference in braking in my 01
  • Tractorman
    Tractorman
    I can't speak for others, but I have 312,000 miles on the original six speed transmission with no repairs.  I replaced the clutch with an OEM clutch at 297,000 miles (failed pilot bearing).  I use the
I put these on mine about 70k miles back and they are holding up quite well. The rotors are holding good even with the ceramic pads.
https://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,brake+&+wheel+hub,rotor+&+brake+pad+kit,138
Does not seem to link the part for some reason. I used the Durago BK70258166 with ceramic pads. For $77.79. Pretty much rolled the dice on them but have been pleasantly surprise.
Edited by dripley
Just a month ago I pulled the caliper.
I'm running the cheapest pads I could my hands on. I'm well over 200k miles on this set and still going. I've just replaced my rear rotors not too long ago not because of the rotor was bad but the top hat part for the parking brake. Grooved too bad for the parking shoes to grab the drum. Rotors where still in excellent condition.
Mine is a 98 so I think thats out.
Doubtful. When you can catch my pad life (200k plus) really doubt bigger is always better.
I would suggest Exhaust Brake over 3rd Gen brakes any day.
E brake is a great thing. I loved mine until it died. Now its just a lump on a shelf. I will have another one day. It will extend brake life extraordinarly long.
If you do... Look at the PacBrake PRXB. That is the best exhaust you can most likely get your hands on. The standard PacBrake isn't bad but the PRXB has a second butterfly that hold back better down low RPM's giving better braking.
They have a $400 rebate untill 5-15. Sure makes it tempting.
Edited by dripley
Well looks like economy brakes it is. Thanks for all the advice. E brake would be sweet but I don’t tow much, well that and I rather get a tuner next.
I use to tow quite a bit be now it all highway empty miles back and forth to Ontario, OR. If you think that Exhaust brakes are for only towing your very much so mistaken. I use it for every stop I make. I foot doesn't touch the brake pedal till I'm down to about 20 to 25 MPH.
I've been flipped off for not having any brake lights. I assure you the brake lights are there and work I just don't use the brake pedal very much. I've even been pulled over by a cop once for not having any brake lights. :lmao::lmao2:
Same here, I enjoyed mine towing or not. It worked quite well on tailgaters.
I have always been told brakes are cheap, transmissions are expensive so stay off the E brake unless you need it. Have you seen any reduction in transmission life as a result?  I’d like on someday if for nothing more than going down the logging road with a load of firewood.  Unfortunately I have to be selective with my wants right now.
I can't speak for others, but I have 312,000 miles on the original six speed transmission with no repairs.  I replaced the clutch with an OEM clutch at 297,000 miles (failed pilot bearing).  I use the exhaust brake on my truck in the exact manner that @Mopar1973Man describes.
- John
I lost 4th gear in the oe 6 speed pre e brake. Put another from a junk yard with 52k on it per them. I have put 220k more on it and about 150k with the e brake with no harm.
Did you find the cause of the 4th gear failure?  How did it fail?  Just curious.
- John
Edited by Tractorman
Just now, Tractorman said:
Did you find the cause of the 4th gear failure?  Just curious.
- John
It is still sitting on a dolly under my work bench. At the time parts were scarce and expensive and rebuilders questionable. I took a chance on the junkyard one with 52k on it. $2500 to my door. Turned out pretty good. As far as loosing 4th, it had been whining some and then while driving home one day I went to shift into 5th and it stuck in 4th. Had to pull off the road and man handle it out of gear. Never went back into 4th. All the other gears worked fine and the tranny made no funny noises but I parked it and found the replacement. All this happened around 250k.
So I guess to answer your question, No.
Well just ordered a set of rotors and ceramic pads from Detroit axle off amazon for 100$ free shipping.  We shall see.
265k miles on the transmission before I broke the main shaft. Already at 114k miles on this transmission. As for the reduction in transmission life, I would say no. Huge reduction in brake wear, no impact on transmission or clutch. Exhaust brake has no wear factor.
From what I understand, most clutch surfaces are not designed to hold high load in the reverse direction. Doing so can cause slippage and wear. The same would likely apply to automatics and manuals. Maybe it's just not bad enough to worry about?
Edited by kzimmer
Spelling
