- Replies 26
 - Views 3.9k
								FumminsDan 12 posts
								Mopar1973Man 6 posts
								Dieselfuture 4 posts
								dripley 3 posts
New here and can really use some help. This might not be the right section to post this but i figured id have better luck here. I just recently finished swapping a 24v into my ford and have been having a problem getting it to start. Before I say this my heater grid is not hooked up and i know its horrible on the motor but the truck will only start with a small hit of ether.Once its started it runs perfect. Idles great sounds smooth and revs up like it should.Once you shut it off and try to start it right back up it wont start. It wont even sputter or sound like its trying to start. The vp44 is brand new and was part of the problem originally when i first started trying to start it. It has since been pulled off and sent back to find it had a defective computer on it. It was repaired and sent back to me but the truck still will not start without ether. I also just sent the ecm off to be checked and they found it had a bad apps and lift pump circuit. It was repaired and sent back and still the truck will not start without ether. Before the ecm was sent off I had a few codes. p0122,p0237,p0336,p1287,p1689. Now that the ecm was repaired im seeing no codes.I also replaced my brand new crank sensor with another brand new sensor just to be sure and still no change. Fass pump cycles on like it should with key on and im getting good pressure at the pump. If anyone has anything they think i can try or check please let me know. Ive been testing wiring and sending parts off for the past two months and im at my breaking point. Thanks for the help.
