- Replies 31
- Views 5.2k
skyhigh4by 11 posts
dripley 8 posts
Me78569 8 posts
Mopar1973Man 4 posts
Our trucks are fueled based on map input. A failed map will result in nearly no fuel.
Probe the map sensor output wire, pin c of the sensor, using a multimeter at Idle state. The Sensor should be outputting near 4.5v. anything more than .25 less than that means your map sensor is rea
Scan Gauge II and others will misreport the MAP sensor. Being Cummins uses a special kind of math to report boost correctly.
Can a failed or failing MAP sensor cause my truck to be very sluggish down low and continuously the P0234 code?
I once upon a time had an edge ez but it’s gone now. The boost elbow that came with it is still installed though. I have a fass lift pump and a FP gauge. Otherwise all stock. Truck feels like a total pig off the line and doesn’t feel like it starts making any power until 1800 rpm or so. Also has trouble holding highway speed in OD on any hills even empty.
