2000 with a 2002 H.O. swap. Crank Sensor
- Replies 5
- Views 1.8k
Me78569 1 post
syndicateshop 1 post
Stanley 1 post
Madmaxxjim 1 post
Hey Everyone! My 2000 3500 has a block with no crank position sensor port behind the starter. I just bought this truck. The previous owner or someone put an external crank tone ring on the front of the balancer with a home made cheezy bracket that holds the crank position sensor bolted to the front oil pan bolts. The truck runs ok but not as good as my other 2000 cummins. I think the crank sensor timing may be off, and it sounds like I have an injector knock. Is there an ECM I can get that eliminates the crank sensor? Someone also told me that I can wire the cam sensor and crank sensor together to fix this. If not should I convert it to the P7100 pump? This is going to be a work truck for the ranch and just need it to be reliable. Thanks!
