Smoke/vapor from vent tube.
I have noticed a big increase in the amount of smoke/vapor from my vent tube, seems to happen since the weather turned hot. Day time or night I can see the vapor coming out around the truck. Runs fine no loss of mpg. Doesn't smoke anymore out of the oil filler hole. Doesn't  use any oil and I only have a drip or two fall into the driveway.  A/c controls, 4x4, and cruise all work as normal.  I did  the moparman mod this winter so it's my first year with it.  Is this normal? Or should I be looking into something?
Edited by Unreal Summit
  • Replies 27
  • Views 7.2k
  • Tractorman
    Tractorman
    @Alexio Auditore is right about checking for a vacuum leak, but using HVAC system for troubleshooting may not be conclusive because there is a check valve in the circuit so the HVAC system can hold va
  • Unreal Summit
    Unreal Summit
    I got most of mine switched over to air brake line. It still reverts back to defrost after the truck is cut off and sits a few mins. However no more smoke coming from the vent tube and I haven't had a
    It can vary from day to day. Some of that is moisture your seeing. As long as you not using oil or blow oil out of the truck your fine. If your concerned pull the injectors and do a compression test.
Would the one way check valve be the round diaphragm that comes off the main line of the vacuum pump
Something like this...
Image result for vacuum check valve
That should help holding the vacuum in the reservoir in the cowl area.
I have to ask, what resevoir? Never seen one on mine.
Mine defauts to the defrost very quickly. Never gave it much thought since it seems to have done that for a very long time. Thought it was like that new but 17.5 years is long time to remember back. Also thought it might just be that check valve. Its 17.5 years old too. Does the vacuum pump have a check valve in it to hold vacuum? I don't remember such when I resealed mine.
Edited by dripley
Maybe its only on the early series of trucks I've for sure seen it on my 1996.
Mine runs to the manifold at the cowl but no resevoir that is visible. thats why I asked. I am still finding surprises with the truck so I dont write anything off.
