Smoke/vapor from vent tube.
- Replies 27
- Views 8.5k
Mopar1973Man 9 posts
Unreal Summit 8 posts
Alexio Auditore 3 posts
dripley 2 posts
@Alexio Auditore is right about checking for a vacuum leak, but using HVAC system for troubleshooting may not be conclusive because there is a check valve in the circuit so the HVAC system can hold va
I got most of mine switched over to air brake line. It still reverts back to defrost after the truck is cut off and sits a few mins. However no more smoke coming from the vent tube and I haven't had a
It can vary from day to day. Some of that is moisture your seeing. As long as you not using oil or blow oil out of the truck your fine. If your concerned pull the injectors and do a compression test.
I have noticed a big increase in the amount of smoke/vapor from my vent tube, seems to happen since the weather turned hot. Day time or night I can see the vapor coming out around the truck. Runs fine no loss of mpg. Doesn't smoke anymore out of the oil filler hole. Doesn't use any oil and I only have a drip or two fall into the driveway. A/c controls, 4x4, and cruise all work as normal. I did the moparman mod this winter so it's my first year with it. Is this normal? Or should I be looking into something?
Edited by Unreal Summit
