- Replies 13
 - Views 4k
								Mopar1973Man 4 posts
								015point9 3 posts
								AH64ID 2 posts
								IBMobile 2 posts
Not that I know of. If the clutch is coming on when under hard load going up hill an turning and off at the top then it's working ok.
Sounds like a 190° thermostat. They crack at ~190°, but aren’t full open until 207°. Max allowable, per Cummims, is 225°. 210° is a perfectly acceptable temp and I wouldn’t worry about i
There is a way to change the locking point of a viscous fan clutch. Basically, you shorten the spring that moves the pin which locks the fan clutch. It is on the very front of the fan clutch. Those
Would this mod be worth it...
Thinking about installing a manual override switch for the fan. My temp gauge goes to about 210 on hard upgrades pulling my trailer (normal I understand) and wondering if it would make any sense to start the fan earlier (somehow) if so how would I hook that up.
